Title:Gryphon: Scaling Hyperscale Multi-Tenant Gateways Beyond the Petabit-Era via DPU-Augmented Hierarchical Co-Offloading
Authors: Yuemeng Xu, Jiarui Guo, Qiuheng Yin, Yangyujia Wang, Zhuochen Fan, Tong Yang (Peking University); Haoran Chen, Mingwei Cui, Cheng Dong, Peng He, Chenmin Sun, Daxiang Kang, Xian Wu, Yang Gao, Lirong Lai, Kai Wang, Hongyu Wu (ByteDance)
This paper studies how to build hyperscale multi-tenant cloud gateways capable of handling petabit-scale aggregate traffic and tens of thousands of tenants. Such gateways sit at the edge of the data center and must simultaneously provide microsecond-level latency, terabit-scale throughput, massive table capacity, and reasonable cost. Existing solutions face a fundamental tradeoff. Software gateways are flexible but cannot sustain the required throughput, while programmable ASIC switches such as Tofino can provide 1.6 Tb/s line-rate forwarding but have severely limited on-chip SRAM and TCAM capacity, typically supporting only about one million entries. This is insufficient for the tens of millions of rules required by large-scale tenant isolation and LLM platforms.
The authors build Gryphon, a hyperscale cloud gateway that integrates programmable DPUs directly into the forwarding path of a Tofino switch. Its core idea is to combine ASIC and DPU capabilities in a hierarchical pipeline: the ASIC handles fast stateless operations, the DPU handles large tables and complex functions, and ARM processors handle exceptional slow-path processing. Through hierarchical and layered co-offloading (HLCO), Gryphon expands table capacity by up to 1,000 times while retaining 1.6 Tb/s line-rate forwarding and adding only approximately 8 microseconds of latency.
Gryphon addresses three major design challenges. It uses a folded pipeline to connect Tofino’s four pipelines and inserts four DPUs in a sandwich-like parallel configuration. Its three-level HLCO architecture assigns work according to processing requirements: Tofino serves the stateless fast path, DPUs provide large-scale state and complex processing, and ARM cores process exceptional cases. The P4Bridge abstraction presents the heterogeneous hardware as one logical pipeline, shielding the control plane from hardware-specific details. The system has operated in ByteDance’s production environment for more than a year across hundreds of nodes and multiple availability zones.
The authors evaluate Gryphon using long-term production deployment and large-scale stress tests. At more than five million flows, the software gateway’s packet-loss rate exceeds 5%, whereas both Tofino-only and Gryphon maintain zero packet loss at ten million flows. In the stable four-million-flow region, Gryphon reduces average latency by 68.7% and P99 latency by 79.3% compared with the software gateway, while adding only about 8 microseconds over Tofino-only. The slow path accounts for less than 0.001% of traffic, and approximately 83% of traffic uses the DPU-assisted fast path. Gryphon increases table capacity by 10–1,000 times, lowers the fraction of time spent in the SRAM-saturated state from over 90% to below 60%, and achieves more than 1,600 Gb/s throughput with over ten times the table capacity in a 2U chassis. This result is significant because it demonstrates a production-validated scale-up path that overcomes the throughput-capacity tradeoff limiting petabit-scale multi-tenant gateways, while avoiding the cost and power penalties of software scale-out.
Q1: What kinds of stateful actions are performed in the switch registers, and how is state synchronized between the switch and the DPU?
A1: The five-tuple (or six-tuple) lookup in this gateway is largely stateless. State is synchronized from the ARM software to the DPU hardware fast path. Packet processing in this paper therefore does not write state into switch registers. Stateful functions such as load balancing are outside the scope of this paper; the traffic evaluated here is largely stateless.
Q2: Do you use any special data-structure design to speed up reads from DPU external memory (DM)?
A2: The on-chip SRAM acts as a cache for the larger DM. The system is still evolving, and the authors are applying optimizations to reduce the number of DM operations. Compiler-level details matter because mathematically equivalent code can behave differently on the hardware, so the DPU implementation needs hardware-friendly code.
Gryphon is a strong example of an industrial systems paper validated by real petabit-scale production traffic rather than only by a laboratory prototype. Its most compelling design choice is the decision to pursue scale-up through ASIC-DPU integration instead of relying solely on scale-out. In gateway workloads, table partitioning and cross-node synchronization can introduce substantial overhead, so combining the speed of ASICs with the capacity of DPUs is a well-motivated approach.
The division of responsibilities among Tofino, the DPU, and ARM processors is also pragmatic and easy to understand. P4Bridge further reduces the software cost of hardware evolution. A key open question is whether this architecture can be generalized across vendors and hardware generations, rather than remaining tightly coupled to one production environment.
