The numbers side
You look at the score. 3-2. You see the numbers. They are simple. They are clear. But they tell a story. Forest scored three. Chelsea scored two. Gibbs-White scored two of the three. That is a high percentage. Two out of three. 66 percent. You do the math. It is impressive. You check BBC. It confirms the details. Gibbs-White is the key. Jesus scored one for Chelsea. One out of two. 50 percent. It is a fair comparison. You think about efficiency. You think about results. You want efficiency in your life. You want results. You do not always get them.
You work hard. You get little. Gibbs-White works hard. He gets two goals. It is better. You respect that. You do the math again. 3-2. The difference is one. One goal. That is the margin. It is small. It is tight. You think about your own margins. You are close to finishing. You are close to success. But you are not there. Yet. Gibbs-White is there. He scored. He won. You are not. You are waiting. You are hoping. You do the math one more time. 3-2.
!nottm forest vs chelsea(https://i.guim.co.uk/img/media/ec2c983a65cbd23166a1c2ba2384b70df15f6fc9/833_0_4783_3827/master/4783.jpg?width=465&dpr=1&s=none&crop=none)
It is a fact. It is not an opinion. It is not a feeling. It is a number. You like numbers. They are safe. They do not change. The game changes. The feelings change. The numbers stay. You write them down. You keep them. You do not forget. You remember. The score is 3-2. Gibbs-White scored twice. Jesus scored once. That is the data. That is the truth. You do not need more. You have enough. You close the app. You go to bed. The numbers stay. You do not. You sleep.
